[GRASS-dev] v.info layer option
Luca Delucchi lucadeluge at gmail.com
Fri May 27 02:00:52 PDT 2016
On 26 May 2016 at 23:21, Markus Metz <markus.metz.giswork at gmail.com> wrote:
> Hi Luca,
Hi Markus
> apparently [0] the layer option is only needed for v.info -c (Print
> types/names of table columns for specified layer instead of info and
> exit). What information about a vector do you want to get? Note that
> vector objects (points, lines, boundaries, areas) are always present,
> even if they are not linked to a layer at all. Maybe v.category
> option=report is more appropriate for your needs?
yes v.category is the right answer, thanks
> A question like this should rather go to the user ml.
yes I suppose it, so I'm going to register there :-)
> Markus M
ciao
Luca
www.lucadelu.org
