[GRASS-dev] GSoC 2016 - PyQt
Ondřej Pešek
pesej.ondrek at gmail.com
Fri May 27 11:12:13 PDT 2016
thanks for your response.
2016-05-25 17:26 GMT+02:00 Pietro <peter.zamb at gmail.com>:
> Perhaps, it could be useful to have a look at pygrass `Module` class [0],
> that already parse the generated xml and instantiate `Parameter` class [1]
> that validate the input from the user in the `_check_value` function [2].
> So should be possible to dynamically generate a `Qt Widget` from a
> `Parameter` instance and then compose everything in complete final
> `QtWidget`/`QtDialog`. If you think that in the `Module` / `Parameter`
> class definition something is missing/wrong or bad implemented, after
> discussion, we can change it. They were not developed with this use case in
> mind and perhaps some changes are needed however I do think they are a
> starting point...
Thank you, 'Module' is really nice. I was working with 'task', but 'Module'
looks much better.
> I think that we should support both: PyQt and PySide, and I think you
> should use as primary choice for development Python3, support for Python2
> it is much easier to add later if needed.
Well, I have never worked with Python3. But of course I can try it. It
might be useful to learn it and if you think it's better. I have created
basics in Python2 but it was one week - so it's not thousands of lines. I
can still retype it. Thanks for idea.
I'm studying the rest (thanks, it really helps me),
Ondrej
<https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail>
Bez
virů. www.avast.com
<#DDB4FAA8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160527/2a82e91e/attachment.html>
