[GRASS-dev] [SoC]Week-1 WebGrass
Luca Delucchi
lucadeluge at gmail.com
Mon May 30 04:56:19 PDT 2016
On 30 May 2016 at 13:36, Rashad Kanavath <mohammedrashadkm at gmail.com> wrote:
> Hello Luca,
> Thanks for testing.
> On Mon, May 30, 2016 at 12:14 PM, Luca Delucchi <lucadeluge at gmail.com>
> wrote:
>> On 30 May 2016 at 11:09, Mayank Agrawal <mayankagrawal333 at gmail.com>
>> wrote:
>> > Readme-
>> > in the webgrass folder https://github.com/rashadkm/webgrass
>> > mkdir build
>> > cd build
>> > cmake ..
>> > make
>> > sudo ./wgrass.wt --http-address=0.0.0.0 --http-port=8080 --docroot ../
>> I read it already, but it was not enough
>> > These are the dependencies which will be required beforehand. Install
>> > them one by one.
>> > libwt-dev - C++ library and application server for web applications
>> > [development]
>> > libwtdbo-dev - Wt::Dbo ORM library for Wt [development]
>> > libwtdbofirebird-dev - Firebird backend for Wt::Dbo [development]
>> > libwtdbomysql-dev - MySQL/MariaDB backend for Wt::Dbo [development]
>> > libwtdbopostgres-dev - PostgreSQL backend for Wt::Dbo [development]
>> > libwtdbosqlite-dev - sqlite3 backend for Wt::Dbo [development]
>> > libwtext-dev - additional widgets for Wt, based on ExtJS 2.0.x
>> > [development]
>> > libwtfcgi-dev - FastCGI connector library for Wt [development]
>> > libwthttp-dev - HTTP(S) connector library for Wt [development]
>> > libwttest-dev - test connector library for Wt [development]
>> > libpugixml-dev
>> please add this in the readme file
>> > After this, do let me know with the error.
>> no error, now I'm able to run it but I cannot modify the grassdata
>> directory, is it normal?
> Yes and No!
> Yes it is expected that there is not user specific location-mapset upload
> ready now.
you could set by default $HOME/grassdata (it is quite common to have a
grassdata in our own $HOME)
> I will push a cmake configuration that downloads sample grass7 dataset. So
> you can test it easily.
no please, no download sample dataset, should be better to set our
grassdata in a cmake variable
ciao
Luca
www.lucadelu.org
