[GRASS-dev] [GRASS GIS] #3197: Memory limit issues with r.univar (when used within i.segment.stats)
GRASS GIS trac at osgeo.org
Thu Nov 3 03:00:26 PDT 2016
  Reporter:  jpduffy  |      Owner:  grass-dev@…
      Type:  defect   |     Status:  new
  Priority:  normal   |  Milestone:  7.0.6
 Component:  Default  |    Version:  7.0.4
Resolution:           |   Keywords:
       CPU:  x86-32   |   Platform:  Linux
Description changed by martinl:
Old description:
> Hello,
> I am trying to use i.segment.stats as part of an OBIA workflow on high
> resolution raster orthomosaics. So far I have used i.segment.uspo,
> i.segment and r.clump to create a layer called gp_seg_optimum_clump.
> Using r.clump means that the clumps are sequentially numbered, whereas
> they are not directly after i.segment.
> I try to run the following command:
> i.segment.stats --overwrite --verbose map=gp_seg_optimum_clump at gp1 \
> rasters=gp_ortho.1 at gp1,gp_ortho.2 at gp1,gp_ortho.3 at gp1,gp_ortho.4 at gp1 \
> raster_statistics=min,max,mean,stddev,variance,sum \
> csvfile=/home/jpd205/Wales_GRASS/GarronPill/gp_seg_stats \
> separator=comma
> And I get the following error:
> Calculating geometry statistics
> Calculating statistics for raster gp_ortho.1 at gp1
> ERROR: G_realloc: unable to allocate 572000 bytes of memory at
>        raster/r.univar/r.univar_main.c:324
> Traceback (most recent call last):
>   File "/home/jpd205/.grass7/addons/scripts/i.segment.stats", line 251,
> in <module>
>     main()
>   File "/home/jpd205/.grass7/addons/scripts/i.segment.stats", line 176,
> in main
>     quiet=True)
>   File "/usr/lib/grass70/etc/python/grass/script/core.py", line 395, in
> run_command
>     return handle_errors(returncode, returncode, args, kwargs)
>   File "/usr/lib/grass70/etc/python/grass/script/core.py", line 313, in
> handle_errors
>     returncode=returncode)
> grass.exceptions.CalledModuleError: Module run None ['r.univar', '--o', '
> --q', '-et', 'zones=gp_seg_optimum_clump at gp1',
> 'output=/home/jpd205/Wales_GRASS/GarronPill/gp1/.tmp/osgeobeefy/6462.0',
> 'map=gp_ortho.1 at gp1'] ended with error
> Process ended with non-zero return code 1. See errors in the (error)
> output.
> Some details about my region settings and data:
> g.region -p
> projection: 99 (OSGB 1936 / British National Grid)
> zone:       0
> datum:      osgb36
> ellipsoid:  airy
> north:      208007.00931776
> south:      207952.59780698
> west:       200993.90853302
> east:       201097.28911076
> nsres:      0.00430914
> ewres:      0.00430914
> rows:       12627
> cols:       23991
> cells:      302934357
> r.info map=gp_seg_optimum_clump
>  | Map:      gp_seg_optimum_clump           Date: Thu Oct 27 14:28:30
> 2016    |
>  | Mapset:   gp1                            Login of Creator: jpd205
>  | Location: GarronPill
>  | DataBase: /home/jpd205/Wales_GRASS
>  | Title:    gp_seg_optimum_clump ( gp_seg_optimum_clump )
>  | Timestamp: none
>  |   Type of Map:  raster               Number of Categories: 0
>  |   Data Type:    CELL
>  |   Rows:         12627
>  |   Columns:      23991
>  |   Total Cells:  302934357
>  |        Projection: OSGB 1936 / British National Grid
>  |            N: 208007.00931776    S: 207952.59780698   Res: 0.00430914
>  |            E: 201097.28911076    W: 200993.90853302   Res: 0.00430914
>  |   Range of data:    min = 1  max = 1264957
>  |   Data Source:
>  |    gp_seg_optimum at gp1
>  |   Data Description:
>  |    generated by r.clump
>  |   Comments:
>  |    r.clump --overwrite --verbose -d input="gp_seg_optimum at gp1"
> output="\   |
>  |    gp_seg_optimum_clump" title="gp_seg_optimum_clump"
> r.info map=gp_ortho.1
>  | Map:      gp_ortho.1                     Date: Mon Oct 17 09:06:32
> 2016    |
>  | Mapset:   gp1                            Login of Creator: jd
>  | Title:     ( gp_ortho.1 )
>  | Timestamp: none
>  |   Data Type:    CELL
>  |   Rows:         12627
>  |   Columns:      23991
>  |   Range of data:    min = 0  max = 255
>  |   Data Description:
>  |    generated by r.in.gdal
>  |   Comments:
>  |    r.in.gdal -o input="/home/jd/GarronPill_R_BNG_PS2_O_C_RGB_TEX.tif"
> o\   |
>  |    utput="gp_ortho" memory=300 offset=0
> Moritz Lennert believes that this is a memory issue limit with r.univar.
> He suggested I submit this bug report.
> Kind regards
> James
New description:
 Hello,
 i.segment and r.clump to create a layer called gp_seg_optimum_clump. Using
 r.clump means that the clumps are sequentially numbered, whereas they are
 separator=comma
   File "/home/jpd205/.grass7/addons/scripts/i.segment.stats", line 251, in
 <module>
     main()
   File "/home/jpd205/.grass7/addons/scripts/i.segment.stats", line 176, in
 main
     quiet=True)
 run_command
 handle_errors
 output.
 g.region -p
 zone:       0
 datum:      osgb36
 ellipsoid:  airy
 nsres:      0.00430914
 ewres:      0.00430914
 rows:       12627
 cols:       23991
 cells:      302934357
  | Map:      gp_seg_optimum_clump           Date: Thu Oct 27 14:28:30 2016
  | Timestamp: none
  |   Data Type:    CELL
  |   Rows:         12627
  |   Columns:      23991
  |   Data Source:
  |   Data Description:
  |   Comments:
 output="\   |
  | Map:      gp_ortho.1                     Date: Mon Oct 17 09:06:32 2016
  | Timestamp: none
  |   Data Type:    CELL
  |   Rows:         12627
  |   Columns:      23991
  |   Data Description:
  |   Comments:
 o\   |
 Kind regards
 James
Ticket URL: <https://trac.osgeo.org/grass/ticket/3197#comment:1>
