[GRASS-dev] [GRASS GIS] #3197: Memory limit issues with r.univar (when used within i.segment.stats)
GRASS GIS trac at osgeo.org
Fri Nov 4 01:25:06 PDT 2016
  Reporter:  jpduffy  |      Owner:  grass-dev@…
      Type:  defect   |     Status:  new
  Priority:  normal   |  Milestone:  7.0.6
 Component:  Default  |    Version:  7.0.4
Resolution:           |   Keywords:
       CPU:  x86-32   |   Platform:  Linux
Comment (by zarch):
 Replying to [ticket:3197 jpduffy]:
 > I get the following error:
 > Calculating geometry statistics
 > Calculating statistics for raster gp_ortho.1 at gp1
 > ERROR: G_realloc: unable to allocate 572000 bytes of memory at
 I had the same problem when I was working OBIA some years ago and I wrote
 r.univar2 that it is available as grass-addons.
 r.univa2 extract some general statistics from raster using the zones
 (consume much less memory than r.univar, and compute more general
 statistics like:skewness, kurtosis, and mode. It is available here:
 https://trac.osgeo.org/grass/browser/grass-addons/grass7/raster/r.univar2
 It was not backported to trunk because it was used only by me and not
 tested enough (imho), and If I remember correctly is working only with
 zones.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3197#comment:2>
