[GRASS-dev] [GRASS GIS] #3200: r.colors is lacking color bars for all predefined colortables
trac at osgeo.org
Sat Nov 5 04:35:26 PDT 2016
Reporter: milenan | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.6
Component: Default | Version: 7.0.5
Keywords: r.colors, v.colors | CPU: x86-64
Platform: MSWindows 8 |
In wxGUI dialog of r.colors drop down list the color bars are missing
under Windows
I discovered in
https://wingrass.fsv.cvut.cz/grass72/x86_64/logs/log-r69771-56/package.log
the following bug:
mingw32/lib:/usr/bin:/mingw64/bin/:/c/OSGeo4W64/bin:/c/msys64/usr/src/grass72_release/mswindows/osgeo4w/lib"
LC_ALL=C /c/msys64/usr/src/grass72_release/tools/thumbnails.py
WARNING: No data base element files found
File "C:/msys64/usr/src/grass72_release/tools/thumbnails.py", line 206,
in <module>
main()
File "C:/msys64/usr/src/grass72_release/tools/thumbnails.py", line 198,
in main
make_image(output_dir, table, grad)
File "C:/msys64/usr/src/grass72_release/tools/thumbnails.py", line 157,
in make_image
convert_and_rotate(tmp_img, outfile, discrete)
File "C:/msys64/usr/src/grass72_release/tools/thumbnails.py", line 105,
in convert_and_rotate
ppmtopng(dst, tmp_img)
File "C:/msys64/usr/src/grass72_release/tools/thumbnails.py", line 89,
in ppmtopng
grass.run_command('g.ppmtopng', input = src, output = dst, quiet =
True)
File
"C:\msys64\usr\src\grass72_release\dist.x86_64-w64-mingw32\etc\python/grass/script/core.py",
line 410, in run_command
return handle_errors(returncode, returncode, args, kwargs)
File
line 329, in handle_errors
returncode=returncode)
grass.exceptions.CalledModuleError: Module run None ['g.ppmtopng', '--q',
'input=C:/msys64/usr/src/grass72_release/dist.x86_64-w64-mingw32\\demolocation\\PERMANENT\\.tmp/unknown\\4072.0.ppm',
'output=C:/msys64/usr/src/grass72_release/dist.x86_64-w64-mingw32\\docs\\html\\colortables\\aspect.png']
ended with error
Process ended with non-zero return code -1073741819. See errors in the
(error) output.
Makefile:16: recipe for target 'thumbnails' failed
make[4]: [thumbnails] Error 1 (ignored)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3200>
