[GRASS-dev] new addon: v.faultdirections
Helmut Kudrnovsky
hellik at web.de
Tue Nov 8 01:59:10 PST 2016
Moritz Lennert wrote
>> but I get an error when using
>> -a Use absolute values in legend, instead of percentages
>> v.faultdirections -a map=test at user1 column=vazimuth
>> Traceback (most recent call last):
>> File "C:\Users\hkmyr\AppData\Roaming\GRASS7\addons/scripts
>> /v.faultdirections.py", line 100, in
> <module>
>> sys.exit(main())
>> /v.faultdirections.py", line 87, in main
>> labelradii = [x for x in np.arange(0,
>> int(np.ceil(max(radii))), labelstep) if x > 0]
>> ZeroDivisionError: division by zero
> This was due to the fact that in your example there are only very few
> lines per direction. I believe I solved this issue in r69786.
> Thanks for testing !
confirmed, it works now.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/new-addon-v-faultdirections-tp5294302p5294779.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
