[GRASS-dev] [GRASS GIS] #3201: wxGUI nviz: resolution settings widget broken in wxPython 3
trac at osgeo.org
Sun Nov 6 11:33:28 PST 2016
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 7.2.0
Component: wxGUI | Version: svn-releasebranch72
Resolution: | Keywords: nviz
CPU: Unspecified | Platform: Linux
Comment (by neteler):
The patch helps for Fine mode/coarse mode, thanks. So it seems to be the
way to go.
Out of size are still
* Under Surface: Transparency + Shininess
* Under "Constant surface", all three SpinCtrls
* Under "Vector" Line width + Icon size
* Under isosurface attributes: Transparency + Shininess
* Under Fringe: Elevation from bottom
* Under Animation: Frame rate
Ticket URL: <https://trac.osgeo.org/grass/ticket/3201#comment:5>
