[GRASS-dev] [GRASS GIS] #3201: wxGUI nviz: resolution settings widget broken in wxPython 3
GRASS GIS trac at osgeo.org
Sun Nov 6 15:13:51 PST 2016
  Reporter:  neteler      |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  critical     |  Milestone:  7.2.0
 Component:  wxGUI        |    Version:  svn-releasebranch72
Resolution:               |   Keywords:  nviz
       CPU:  Unspecified  |   Platform:  Linux
Comment (by annakrat):
 Replying to [comment:5 neteler]:
 > The patch helps for Fine mode/coarse mode, thanks. So it seems to be the
 way to go.
 > Out of size are still
 >  * Under Surface: Transparency + Shininess
 >  * Under "Constant surface", all three SpinCtrls
 >  * Under "Vector" Line width + Icon size
 >  * Under isosurface attributes: Transparency + Shininess
 >  * Under Fringe: Elevation from bottom
 >  * Under Animation: Frame rate
 and probably more. This issue applies to almost all SpinCtrls in different
 parts of GUI (dialogs, attribute table manager, ...), right? So all these
 have to be changed. Could you find the minimum size which works for your
 platform? The problem is, it's way to big for all other platforms, so
 ideally this would be applied only to your platform, but I need to
 recognize it in the code somehow.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3201#comment:6>
