[GRASS-dev] g.gui.tplot: AttributeError: 'module' object has no attribute 'EVT_COMBOBOX_CLOSEUP'
Luca Delucchi lucadeluge at gmail.com
Wed Nov 16 14:41:31 PST 2016
On 16 November 2016 at 23:24, Veronica Andreo <veroandreo at gmail.com> wrote:
> Ciao Lu,
Ciao Vero,
> I've noticed that if I open g.gui.tplot from the GUI I can see the pointer
> icon (arrow) to select a point in the map, however if I call g.gui.tplot
> from the terminal, that pointer (arrow) is not there and the only option is
> to copy/paste or type the coordinates. Is there a reason for that behaviour?
> Is it on purpose?
Yes, at least when I developed it I found the same behaviour in other
gui modules. I don't know if other solutions are possible, but
probably is not simple to implement it.
> Cheers,
> Vero
PS
Sorry if I didn't work much on this but I'm a little bit busy, I hope
to find some time before Christmas.
ciao
Luca
www.lucadelu.org
