[GRASS-dev] g.gui.tplot: AttributeError: 'module' object has no attribute 'EVT_COMBOBOX_CLOSEUP'
Veronica Andreo
veroandreo at gmail.com
Wed Nov 16 23:16:54 PST 2016
Hello Anna,
2016-11-16 23:30 GMT+01:00 Anna Petrášová <kratochanna at gmail.com>:
> On Wed, Nov 16, 2016 at 5:24 PM, Veronica Andreo <veroandreo at gmail.com>
> wrote:
> > Ciao Lu,
> > I've noticed that if I open g.gui.tplot from the GUI I can see the
> pointer
> > icon (arrow) to select a point in the map, however if I call g.gui.tplot
> > from the terminal, that pointer (arrow) is not there and the only option
> is
> > to copy/paste or type the coordinates. Is there a reason for that
> behaviour?
> > Is it on purpose?
> if you run it from the terminal, it does not know about any monitors
> or gui to pick the coordinate from, so there is no easy way to
> implement this
ah, I understand. The issue is more general that g.gui.tplot, then...
Thanks for clarification :)
Vero
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20161117/6f66e67c/attachment.html>
