[GRASS-dev] v.select features without category skipped
Moritz Lennert
mlennert at club.worldonline.be
Thu Nov 17 09:38:02 PST 2016
On 17/11/16 18:06, Moritz Lennert wrote:
> On 17/11/16 14:11, Luca Delucchi wrote:
>> Hi devs,
>> this morning I got a problem with v.select, I don't understand if is a
>> bug or what... I repeated the procedure with north carolina dataset
>> g.region vect=zipcodes -ap
>> v.mkgrid map=zipcodes_grid box=10000,10000
>> v.category zipcodes_grid opt=report
>> Layer/table: 1/zipcodes_grid
>> type count min max
>> point 0 0 0
>> line 0 0 0
>> boundary 0 0 0
>> centroid 42 1 42
>> area 0 0 0
>> face 0 0 0
>> kernel 0 0 0
>> all 42 1 42
>> v.select ain=zipcodes_grid bin=zipcodes operator=touches
>> out=zipcodes_grid_final --o
>> WARNING: Vector map <zipcodes_grid_final> already exists and will be
>> overwritten
>> Processing features...
>> 100%
>> Processing areas...
>> 100%
>> Writing selected features...
>> 100%
>> Writing attributes...
>> WARNING: Array of values to select from column <cat> is empty
> i.e. no features found which is logical, as there are no zipcode areas
> that touch a grid area. 'touches' is normally defined as [1]
> "a touches b: they have at least one boundary point in common, but no
> interior points."
> Try with intersects, overlaps, etc.
> I agree though that the error message is very unclear. After the "Array
> of values ... is empty" it should just stop. After a very rapid look at
> main.c of v.select it seems to me that it doesn't check the result of
> the selection and just goes on trying to write a new file...
Try the attached patch. Not very elegant and not well tested, but seems
to work for me.
Moritz
Type: text/x-patch
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20161117/433cb6ef/attachment.bin>
