[GRASS-dev] v.select features without category skipped
Moritz Lennert
mlennert at club.worldonline.be
Thu Nov 17 09:06:50 PST 2016
On 17/11/16 14:11, Luca Delucchi wrote:
> Hi devs,
> this morning I got a problem with v.select, I don't understand if is a
> bug or what... I repeated the procedure with north carolina dataset
> g.region vect=zipcodes -ap
> v.mkgrid map=zipcodes_grid box=10000,10000
> v.category zipcodes_grid opt=report
> Layer/table: 1/zipcodes_grid
> type count min max
> point 0 0 0
> line 0 0 0
> boundary 0 0 0
> centroid 42 1 42
> area 0 0 0
> face 0 0 0
> kernel 0 0 0
> all 42 1 42
> v.select ain=zipcodes_grid bin=zipcodes operator=touches
> out=zipcodes_grid_final --o
> WARNING: Vector map <zipcodes_grid_final> already exists and will be
> overwritten
> Processing features...
> 100%
> Processing areas...
> 100%
> Writing selected features...
> 100%
> Writing attributes...
> WARNING: Array of values to select from column <cat> is empty
i.e. no features found which is logical, as there are no zipcode areas
that touch a grid area. 'touches' is normally defined as [1]
"a touches b: they have at least one boundary point in common, but no
interior points."
Try with intersects, overlaps, etc.
I agree though that the error message is very unclear. After the "Array
of values ... is empty" it should just stop. After a very rapid look at
main.c of v.select it seems to me that it doesn't check the result of
the selection and just goes on trying to write a new file...
Moritz
[1] https://en.wikipedia.org/wiki/DE-9IM
