[GRASS-dev] man error on compilation
Yann Chemin dr.yann.chemin at gmail.com
Tue Nov 22 10:01:49 PST 2016
Thanks Vaclav,
the error came when I would not flush all containers from previous build.
If I build with --no-cache, the issue does not come.
Thanks for the check on empty keywords list, I am rebuilding it now.
Yann
Yann Chemin
Planetary Scientist
Latest: https://peerj.com/preprints/2124/
*JRC:*
https://www.thefreelibrary.com/3628+-+CANHEMON+Remote+sensing+based+forest+canopy+health+monitoring...-a0453990005
*OSGeo: *https://wiki.osgeo.org/wiki/Open_Monitoring_Systems_Working_Group
On 22 November 2016 at 18:58, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> On Tue, Nov 22, 2016 at 11:12 AM, Yann Chemin <dr.yann.chemin at gmail.com>
> wrote:
>> I am compiling from SVN inside a docker (Debian testing)
> I'm just doing it with Ubuntu in Docker and I have no issue with r68881
> (docker run ... grass --config revision).
>> for some reason inside man/ the build_keywords.py bugs at line 63.
> This looks like module without keywords or with an empty keyword. Are you
> using something else than code from trunk?
>> GISBASE="/root/dev/grass_trunk/dist.x86_64-pc-linux-gnu"
>> ARCH="x86_64-pc-linux-gnu" ARCH_DISTDIR="/root/dev/grass_
>> trunk/dist.x86_64-pc-linux-gnu" VERSION_NUMBER=7.3.svn VERSION_DATE=2016
>> python ./build_keywords.py /root/dev/grass_trunk/dist.x86
>> _64-pc-linux-gnu/docs/html
>> Traceback (most recent call last):
>>   File "./build_keywords.py", line 63, in <module>
>>     firstchar = key[0].lower()
>> IndexError: string index out of range
> r69871 checks for an empty keyword and fail because empty keyword should
> not happen. The error message tells file and line.
> Hope this helps,
> Vaclav
> https://trac.osgeo.org/grass/changeset/69871
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20161122/b1cedaaa/attachment.html>
