[GRASS-dev] [GRASS GIS] #3210: r.texture: bug when non continuous series of values
GRASS GIS trac at osgeo.org
Wed Nov 23 04:31:44 PST 2016
  Reporter:  mlennert     |      Owner:  grass-dev@…
      Type:  defect       |     Status:  reopened
  Priority:  normal       |  Milestone:  7.2.0
 Component:  Raster       |    Version:  svn-trunk
Resolution:               |   Keywords:  r.texture
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by mlennert):
 Thanks for all these fixes !
 r.texture now runs much faster than before and results seem more
 meaningful. I'll attach an image with results of running
 r.texture lsat7_2002_80 -a
 using 7.0.5 (left) and current trunk (right) for each of the texture
 indicators. On 7.0.5 this takes over 2 minutes, where in trunk it takes
 less than 30 seconds.
 Several results now seem more relevant (SV, SA, DV, Contrast). Others do
 not change. I don't know whether this is because they were already ok or
 not. Variance seems to be less clear after the change. And MOC-2 doesn't
 give any result (0 everywhere) in both versions.
 I think r.texture is already much better than before, but still needs some
 serious revision to make sure that all the indicators are actually
 calculated correctly.
 I don't know if we just leave this bug open, or whether we should open a
 separate bug.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3210#comment:20>
