[GRASS-dev] [GRASS GIS] #3210: r.texture: bug when non continuous series of values
trac at osgeo.org
Wed Nov 23 04:54:05 PST 2016
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: reopened
Priority: normal | Milestone: 7.2.0
Component: Raster | Version: svn-trunk
Resolution: | Keywords: r.texture
CPU: Unspecified | Platform: Unspecified
Comment (by mlennert):
Replying to [comment:20 mlennert]:
>And MOC-2 doesn't give any result (0 everywhere) in both versions.
Trying to debug this, I am a bit stumped. Using the following debug patch:
Index: h_measure.c
--- h_measure.c (révision 69876)
+++ h_measure.c (copie de travail)
@@ -669,7 +669,9 @@
- /* fprintf(stderr,"hx=%f\thxy2=%f\n",hx,hxy2); */
+ fprintf(stderr, "1-exp() = %f\n", (1 - exp(-2.0 * (hxy2 - hxy))));
+ fprintf(stderr, "abs() = %f\n", abs(1 - exp(-2.0 * (hxy2 - hxy))));
+ fprintf(stderr, "sqrt() = %f\n", sqrt(abs(1 - exp(-2.0 * (hxy2 -
hxy)))));
return (sqrt(abs(1 - exp(-2.0 * (hxy2 - hxy)))));
I get results such as:
1-exp() = 0.994315
abs() = 0.994315
sqrt() = 0.000000
1-exp() = 0.993262
abs() = 0.993262
sqrt() = 0.000000
1-exp() = 0.994315
abs() = 0.994315
sqrt() = 0.000000
1-exp() = 0.993262
abs() = 0.993262
sqrt() = 0.000000
So something seems to be wrong in the sqrt() calculations. However, when I
comment out the first fprintf() in the above patch, I get this:
abs() = 0.000000
sqrt() = 0.000000
abs() = 0.000000
sqrt() = 0.000000
abs() = 0.000000
sqrt() = 0.000000
abs() = 0.000000
sqrt() = 0.000000
abs() = 0.000000
sqrt() = 0.000000
No idea how to interpret this behaviour.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3210#comment:21>
