[GRASS-dev] [GRASS GIS] #3210: r.texture: bug when non continuous series of values
trac at osgeo.org
Sat Nov 26 06:12:38 PST 2016
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: reopened
Priority: normal | Milestone: 7.2.0
Component: Raster | Version: svn-trunk
Resolution: | Keywords: r.texture
CPU: Unspecified | Platform: Unspecified
Comment (by neteler):
Replying to [comment:28 mlennert]:
> Ok, I've moved things around quite a lot and added some more notes. Now
the description is short and focuses on the explanation of the actual
parameters of the module and more detailed content discussion is in the
notes.
> IMHO, this is ready to go into the other branches, especially 7.2 before
its release. However, should I merge all of the different commits we did
in the last days, or can I just copy over the r.texture.html file ? Don't
know what consequences that has on svn history...
Current best practice in case of '''HTML pages''':
copy over the entire file if you want everything to be taken over (or use
e.g. "meld" otherwise). Then a commit mesg like this:
svn ci -m"r.texture manual: sync to trunk (rxxx, ryyy, ...)"
raster/r.texture/r.texture.html
Like this anyone can look up the individual modifications. We stopped
copying the svn history across branches some time ago since it caused more
troubles than gave advantages.
Note: in case of C or Python source code backports this script is better:
grass-addons/tools/svn-merge.sh
Ticket URL: <https://trac.osgeo.org/grass/ticket/3210#comment:29>
