[GRASS-dev] [GRASS GIS] #3210: r.texture: bug when non continuous series of values
trac at osgeo.org
Sun Nov 27 07:07:06 PST 2016
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: reopened
Priority: normal | Milestone: 7.2.0
Component: Raster | Version: svn-trunk
Resolution: | Keywords: r.texture
CPU: Unspecified | Platform: Unspecified
Comment (by mlennert):
Replying to [comment:29 neteler]:
> Replying to [comment:28 mlennert]:
> > Ok, I've moved things around quite a lot and added some more notes.
Now the description is short and focuses on the explanation of the actual
parameters of the module and more detailed content discussion is in the
notes.
> > IMHO, this is ready to go into the other branches, especially 7.2
before its release. However, should I merge all of the different commits
we did in the last days, or can I just copy over the r.texture.html file ?
Don't know what consequences that has on svn history...
> Current best practice in case of '''HTML pages''':
> copy over the entire file if you want everything to be taken over (or
use e.g. "meld" otherwise). Then a commit mesg like this:
> svn ci -m"r.texture manual: sync to trunk (rxxx, ryyy, ...)"
raster/r.texture/r.texture.html
> Like this anyone can look up the individual modifications. We stopped
copying the svn history across branches some time ago since it caused more
troubles than gave advantages.
Thanks for the guidance.
Man page updated in rel72 and rel70 (r69926 - r69929).
Ticket URL: <https://trac.osgeo.org/grass/ticket/3210#comment:30>
