[GRASS-dev] tgrass: PERMANENT/tgis/sqlite.db do not exists
Sören Gebbert soerengebbert at googlemail.com
Wed Nov 30 05:03:48 PST 2016
t.list checks all mapsets in the mapset search path set with g.mapsets.
Since PERMANENT is always in the search path it will always be checked.
However, i think the check is too noisy and should be changed, but i have
no better concept for now.
Ciao
Sören
2016-11-30 13:45 GMT+01:00 Martin Landa <landa.martin at gmail.com>:
> Hi,
> when calling t.list from user mapset:
> $ g.mapset -p
> pisek_tabor
> $ t.list
> WARNING: Temporal database connection defined as:
> /work/geodata/grassdata/zddp-landsat/PERMANENT/tgis/sqlite.db
> But database file does not exist.
> Space time raster datasets with absolute time available in mapset
> <pisek_tabor>:
> pt at pisek_tabor
> Why t.list checks also TGIS in PERMANENT in this case? Thanks, Ma
> Martin Landa
> http://geo.fsv.cvut.cz/gwiki/Landa
> http://gismentors.cz/mentors/landa
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20161130/6833a57b/attachment.html>
