[GRASS-dev] tgrass: PERMANENT/tgis/sqlite.db do not exists
Martin Landa
landa.martin at gmail.com
Wed Nov 30 05:12:56 PST 2016
2016-11-30 14:03 GMT+01:00 Sören Gebbert <soerengebbert at googlemail.com>:
> t.list checks all mapsets in the mapset search path set with g.mapsets.
> Since PERMANENT is always in the search path it will always be checked.
> However, i think the check is too noisy and should be changed, but i have no
> better concept for now.
yes, it's too noisy. I would even say that this warning could be
turned to debug message. Martin
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
