[GRASS-dev] [GRASS-SVN] r69651 - grass/trunk/vector/v.external
Vaclav Petras wenzeslaus at gmail.com
Mon Oct 3 10:00:48 PDT 2016
Hi Martin,
regarding r69651, would you consider moving the code to a function in a
separate file or preferable putting it to the library? There is several
modules which have similar code.
Thanks,
Vaclav
On Mon, Oct 3, 2016 at 11:47 AM, <svn_grass at osgeo.org> wrote:
> Author: martinl
> Date: 2016-10-03 08:47:30 -0700 (Mon, 03 Oct 2016)
> New Revision: 69651
> Added:
>    grass/trunk/vector/v.external/proj.c
> Modified:
>    grass/trunk/vector/v.external/local_proto.h
>    grass/trunk/vector/v.external/main.c
> Log:
> v.external: fix check projection
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20161003/1401ca39/attachment.html>
