[GRASS-dev] [GRASS-SVN] r69651 - grass/trunk/vector/v.external
Martin Landa
landa.martin at gmail.com
Mon Oct 3 10:17:31 PDT 2016
2016-10-03 19:00 GMT+02:00 Vaclav Petras <wenzeslaus at gmail.com>:
> regarding r69651, would you consider moving the code to a function in a
the code has been already moved to a function - check_projection() in
a separate file (proj.c).
> separate file or preferable putting it to the library? There is several
> modules which have similar code.
Yes, long-term wish, there should be already ticket reported. Ma
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
