[GRASS-dev] g.gui.tplot: AttributeError: 'module' object has no attribute 'EVT_COMBOBOX_CLOSEUP'
Anna Petrášová kratochanna at gmail.com
Wed Oct 5 15:10:49 PDT 2016
On Mon, Oct 3, 2016 at 6:14 PM, Blumentrath, Stefan
<Stefan.Blumentrath at nina.no> wrote:
> Hi,
> In the context of https://trac.osgeo.org/grass/ticket/3057 I just tested
> g.gui.tplot from GRASS 7.2 (r68908) on a STRDS and got the following error
> message:
> Traceback (most recent call last):
>   File "/usr/local/grass-7.2.svn/scripts/g.gui.tplot", line
> 130, in <module>
>     main()
> 116, in main
>     frame = TplotFrame(parent=None,
> giface=StandaloneGrassInterface())
>   File
> "/usr/local/grass-7.2.svn/gui/wxpython/tplot/frame.py", line
> 106, in __init__
>     self._layout()
>   File
> 230, in _layout
>     self.datasetSelectV.Bind(wx.EVT_COMBOBOX_CLOSEUP,
> I am on Ubuntu 14.04 LTS. Is that related to #3057? Any other ideas?
not related. This GUI event is apparently not supported. From documentation:
Notice that this event is only supported by wxMSW, wxGTK with GTK+
2.10 or later, and OSX/Cocoa.
What version of gtk do you use?
Anyway, we have to replace this event. It would be best to create a
ticket for this.
Anna
> Cheers
> Stefan
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
