[GRASS-dev] g.gui.tplot: AttributeError: 'module' object has no attribute 'EVT_COMBOBOX_CLOSEUP'
Blumentrath, Stefan
Stefan.Blumentrath at nina.no
Thu Oct 6 04:00:53 PDT 2016
Hei Anna,
Thanks for your reply!
Seems I have both gtk 2.8 and gtk 3.0 on my system.
But I only found libwxgtk2.8-dev and since GRASS is selfcompiled I guess it is build against 2.8...
Shall try to build against 3.0.
Anyway, ticket opened here: https://trac.osgeo.org/grass/ticket/3175
Cheers
Stefan
-----Original Message-----
From: Anna Petrášová [mailto:kratochanna at gmail.com]
Sent: 6. oktober 2016 00:11
To: Blumentrath, Stefan <Stefan.Blumentrath at nina.no>
Cc: GRASS developers list (grass-dev at lists.osgeo.org) <grass-dev at lists.osgeo.org>
Subject: Re: [GRASS-dev] g.gui.tplot: AttributeError: 'module' object has no attribute 'EVT_COMBOBOX_CLOSEUP'
On Mon, Oct 3, 2016 at 6:14 PM, Blumentrath, Stefan <Stefan.Blumentrath at nina.no> wrote:
> Hi,
> In the context of https://trac.osgeo.org/grass/ticket/3057 I just
> tested g.gui.tplot from GRASS 7.2 (r68908) on a STRDS and got the
> following error
> message:
> Traceback (most recent call last):
> File "/usr/local/grass-7.2.svn/scripts/g.gui.tplot", line
> 130, in <module>
> main()
> 116, in main
> frame = TplotFrame(parent=None,
> giface=StandaloneGrassInterface())
> File
> "/usr/local/grass-7.2.svn/gui/wxpython/tplot/frame.py", line
> 106, in __init__
> self._layout()
> File
> 230, in _layout
> self.datasetSelectV.Bind(wx.EVT_COMBOBOX_CLOSEUP,
> I am on Ubuntu 14.04 LTS. Is that related to #3057? Any other ideas?
not related. This GUI event is apparently not supported. From documentation:
Notice that this event is only supported by wxMSW, wxGTK with GTK+
2.10 or later, and OSX/Cocoa.
What version of gtk do you use?
Anyway, we have to replace this event. It would be best to create a ticket for this.
Anna
> Cheers
> Stefan
> grass-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-dev
