[GRASS-dev] Default behavior of g.list displaying all mapsets content
    Moritz Lennert
    mlennert at club.worldonline.be
    Wed Oct 19 02:47:43 PDT 2016
On 19/10/16 11:22, Margherita Di Leo wrote:
> Dear all,
> currently the default behavior of g.list is to display all the files
> present in all mapsets (which corresponds to g.list mapset=*), without
> indicating where they are.
> I would very much prefer g.list mapset=. as a default behavior, ignoring
> what there is in other mapsets.
-1
For me the current default behaviour, i.e. showing maps of all mapsets
in the current search path is much more useful.
> If this is really not possible, at least specifying the mapset where the
> maps are, if different from the current.
> Perhaps:
> g.list vect
> vect1
> vect2
> PERMANENT
> vect3
> or:
> g.list vect
> vect1
> vect2
> PERMANENT/vect3
> What do you think?
Have you seen the '-m' flag ?
And otherwise, the '-p' flag gives you pretty printed output by mapset.
I guess we could discuss whether '-p' should be the default...
There was a discussion about these questions on the ML at the time:
https://lists.osgeo.org/pipermail/grass-dev/2014-October/071381.html
Moritz
