[GRASS-dev] [GRASS GIS] #3184: v.vect.stats: errors in counts and statistics
GRASS GIS trac at osgeo.org
Thu Oct 20 12:43:19 PDT 2016
  Reporter:  veroandreo  |      Owner:  grass-dev@…
      Type:  defect      |     Status:  new
  Priority:  normal      |  Milestone:  7.2.0
 Component:  Vector      |    Version:  svn-trunk
Resolution:              |   Keywords:  v.vect.stats
       CPU:  x86-64      |   Platform:  Linux
Comment (by veroandreo):
 When I apply this second patch (having the first already applied), I get:
 [veroandreo at 192 grass-7.3.svn]$ patch -p0 <
 v_vect_stats_unique_cats.2.diff
 patching file vector/v.vect.stats/main.c
 Hunk #2 FAILED at 100.
 Hunk #3 FAILED at 461.
 Hunk #4 succeeded at 660 (offset 2 lines).
 2 out of 4 hunks FAILED — saving rejects to file
 vector/v.vect.stats/main.c.rej
 If anyway I try to use v.vect.stats with the first test data (areas_test
 and points_test), I get Segmentation fault. But maybe that's because the
 patch is not fully/correctly applied? I'm using latest trunk revision
 (r69713M).
 ps: thanks for clarification regarding v.category, v.db.update and so on
Ticket URL: <https://trac.osgeo.org/grass/ticket/3184#comment:8>
