[GRASS-dev] [GRASS GIS] #3184: v.vect.stats: errors in counts and statistics
GRASS GIS trac at osgeo.org
Thu Oct 20 13:15:28 PDT 2016
  Reporter:  veroandreo  |      Owner:  grass-dev@…
      Type:  defect      |     Status:  new
  Priority:  normal      |  Milestone:  7.2.0
 Component:  Vector      |    Version:  svn-trunk
Resolution:              |   Keywords:  v.vect.stats
       CPU:  x86-64      |   Platform:  Linux
Comment (by neteler):
 Replying to [comment:8 veroandreo]:
 > When I apply this second patch (having the first already applied),
 You likely need to revert the first patch if the second was generated
 against SVN.
 svn revert file(s)
 # verify
 svn status
 Then apply the second alias new patch (I didn't try myself but this would
 be the common procedure).
Ticket URL: <https://trac.osgeo.org/grass/ticket/3184#comment:9>
