[GRASS-dev] [GRASS GIS] #3184: v.vect.stats: errors in counts and statistics
GRASS GIS trac at osgeo.org
Thu Oct 20 14:55:15 PDT 2016
  Reporter:  veroandreo  |      Owner:  grass-dev@…
      Type:  defect      |     Status:  new
  Priority:  normal      |  Milestone:  7.2.0
 Component:  Vector      |    Version:  svn-trunk
Resolution:              |   Keywords:  v.vect.stats
       CPU:  x86-64      |   Platform:  Linux
Comment (by veroandreo):
 Ahhh! Thanks for the explanation :)
 So, I applied the second patch "instead" of the first one, and it works as
 expected, at least for the counts of points in polygons. I tested both
 with the test data previously attached and with data of my own. Thanks so
 much! I will test more and report back :)
 Regarding the statistics... I'm not sure how to, but even if the attribute
 data in the points is integer, wouldn't that be better to have the "real"
 average, standard deviation, etc., and not a truncated version of them??
Ticket URL: <https://trac.osgeo.org/grass/ticket/3184#comment:10>
