[GRASS-dev] r.out.gdal and Rasterlite driver
Vincent Bain
bain at toraval.fr
Mon Oct 24 02:05:09 PDT 2016
Thank you Helmut,
I open a ticket.
V.
Le lundi 24 octobre 2016 à 01:44 -0700, Helmut Kudrnovsky a écrit :
> Vincent Bain wrote
> > Hello,
> > following a previous post on the users ML[1], I am planning to open a
> > new ticket concerning an issue I met trying to export raster maps to a
> > spatialite database. It looks like the output raster table lacks a
> > correct reference to the srid it should be linked to, i.e. in the
> > geometry_column table, srid equals -1 for the newly written raster
> > table.
> > Would anyone mind having a try running r.out.gdal with his/her data to
> > check if the problem is due to my configuration or actually a bug in the
> > command ?
> > Thank you,
> > Vincent.
> > [1]https://lists.osgeo.org/pipermail/grass-user/2016-October/075413.html
> > grass-dev mailing list
> > grass-dev at .osgeo
> > http://lists.osgeo.org/mailman/listinfo/grass-dev
> Tested here with the NC sample data set and grass trunk on windows and
> linux.
> missing srs confirmed.
> best regards
> Helmut
> View this message in context: http://osgeo-org.1560.x6.nabble.com/r-out-gdal-and-Rasterlite-driver-tp5292212p5292236.html
> Sent from the Grass - Dev mailing list archive at Nabble.com.
> grass-dev at lists.osgeo.org
