[GRASS-dev] r.out.gdal and Rasterlite driver
Helmut Kudrnovsky hellik at web.de
Mon Oct 24 01:44:08 PDT 2016
Vincent Bain wrote
> Hello,
> following a previous post on the users ML[1], I am planning to open a
> new ticket concerning an issue I met trying to export raster maps to a
> spatialite database. It looks like the output raster table lacks a
> correct reference to the srid it should be linked to, i.e. in the
> geometry_column table, srid equals -1 for the newly written raster
> table.
> Would anyone mind having a try running r.out.gdal with his/her data to
> check if the problem is due to my configuration or actually a bug in the
> command ?
> Thank you,
> Vincent.
> [1]https://lists.osgeo.org/pipermail/grass-user/2016-October/075413.html
> grass-dev mailing list
> grass-dev at .osgeo
> http://lists.osgeo.org/mailman/listinfo/grass-dev
Tested here with the NC sample data set and grass trunk on windows and
linux.
missing srs confirmed.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/r-out-gdal-and-Rasterlite-driver-tp5292212p5292236.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
