[GRASS-dev] [GRASS GIS] #3193: r.out.gdal: add AUTHORITY node to the srs info of the exported raster
trac at osgeo.org
Mon Oct 24 10:55:19 PDT 2016
Reporter: hellik | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: major | Milestone: 7.2.0
Component: Raster | Version: svn-trunk
Keywords: | CPU: All
Platform: All |
test case in a location created by an EPSG code
g.proj -p
-PROJ_INFO-------------------------------------------------
name : MGI / Austria GK Central
datum : hermannskogel
ellps : bessel
proj : tmerc
lat_0 : 0
lon_0 : 13.33333333333333
k : 1
x_0 : 0
y_0 : -5000000
no_defs : defined
towgs84 : 577.326,90.129,463.919,5.1366,1.4742,5.2970,2.4232
-PROJ_EPSG-------------------------------------------------
epsg : 31255
-PROJ_UNITS------------------------------------------------
unit : meter
units : meters
meters : 1
export a raster by r.out.gdal and do gdalinfo
gdalinfo raster_export_by_grass.tif
Driver: GTiff/GeoTIFF
Files: raster_export_by_grass.tif
Size is 7201, 7001
Coordinate System is:
PROJCS["MGI / Austria GK Central",
GEOGCS["bessel",
DATUM["Militar_Geographische_Institute",
SPHEROID["Bessel_1841",6377397.155,299.1528128],
TOWGS84[577.326,90.129,463.919,5.1366,1.4742,5.297,2.4232]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433]],
PROJECTION["Transverse_Mercator"],
PARAMETER["latitude_of_origin",0],
PARAMETER["central_meridian",13.33333333333333],
PARAMETER["scale_factor",1],
PARAMETER["false_easting",0],
PARAMETER["false_northing",-5000000],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]]]
Origin = (-96005.000000000000000,230005.000000000000000)
Pixel Size = (10.000000000000000,-10.000000000000000)
Metadata:
AREA_OR_POINT=Area
TIFFTAG_SOFTWARE=GRASS GIS 7.3.svn with GDAL 2.1.1
Image Structure Metadata:
INTERLEAVE=BAND
Corner Coordinates:
Upper Left ( -96005.000, 230005.000) ( 12d 3'57.90"E, 47d12' 8.96"N)
Lower Left ( -96005.000, 159995.000) ( 12d 4'50.98"E, 46d34'22.11"N)
Upper Right ( -23995.000, 230005.000) ( 13d 0'59.64"E, 47d12'32.62"N)
Lower Right ( -23995.000, 159995.000) ( 13d 1'12.91"E, 46d34'45.25"N)
Center ( -60000.000, 195000.000) ( 12d32'45.35"E, 46d53'30.77"N)
do gdal_translate and assign the srs
gdal_translate -a_srs EPSG:31255 raster_export_by_grass.tif
geotif_by_gdaltranslate.tif
check by gdalinfo
gdalinfo geotif_by_gdaltranslate.tif
Files: geotif_by_gdaltranslate.tif
geotif_by_gdaltranslate.tif.aux.xml
Size is 7201, 7001
GEOGCS["MGI",
SPHEROID["Bessel 1841",6377397.155,299.1528128,
AUTHORITY["EPSG","7004"]],
TOWGS84[577.326,90.129,463.919,5.137,1.474,5.297,2.4232],
AUTHORITY["EPSG","6312"]],
PRIMEM["Greenwich",0,
AUTHORITY["EPSG","8901"]],
UNIT["degree",0.0174532925199433,
AUTHORITY["EPSG","9122"]],
AUTHORITY["EPSG","4312"]],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]],
AUTHORITY["EPSG","31255"]] <<==
Metadata:
AREA_OR_POINT=Area
INTERLEAVE=BAND
Corner Coordinates:
GDAL adds the ''AUTHORITY node'' of the corresponding EPSG code.
this may be help #3191 (and maybe also other GIS software reading GRASS
exported data).
also mentioned in a [https://lists.osgeo.org/pipermail/gdal-
dev/2016-October/045359.html GDAL ML thread]:
From what I can see the driver doesn't handle adding a new entry in the
spatial_ref_sys table if there's no AUTHORITY node, such as in your use
case.
Make sure a EPSG code is attached to
the input dataset, or assign it explictly
Ticket URL: <https://trac.osgeo.org/grass/ticket/3193>
