[GRASS-dev] [GRASS GIS] #2996: Lidar modules broken in 64bit WinGRASS
trac at osgeo.org
Mon Oct 24 11:58:38 PDT 2016
Reporter: wenzeslaus | Owner: grass-dev@…
Type: defect | Status: reopened
Priority: critical | Milestone: 7.0.5
Component: Packaging | Version: svn-releasebranch70
Resolution: | Keywords: lasinfo, r.in.lidar, v.in.lidar,
| r3.in.lidar, libLAS
CPU: x86-64 | Platform: Unspecified
Comment (by hellik):
Replying to [comment:13 hellik]:
> tested here with
> System Info
> GRASS version: 7.3.svn
> GRASS SVN revision: r69714
> Build date: 2016-10-24
> Build platform: i386-w64-mingw32
> GDAL: 2.1.1
> PROJ.4: 4.9.3
> GEOS: 3.5.0
> SQLite: 3.14.1
> Python: 2.7.4
> wxPython: 2.8.12.1
> Platform: Windows-Vista-6.0.6002-SP2 (OSGeo4W)
now tested with
System Info
GRASS Version: 7.3.svn
Build platform: x86_64-w64-mingw32
GDAL: 2.1.1
PROJ.4: 4.9.3
GEOS: 3.5.0
SQLite: 3.14.1
Python: 2.7.5
wxPython: 2.8.12.1
Platform: Windows-8-6.2.9200 (OSGeo4W)
lasinfo Serpent_Mound_Model_LAS_Data.las
Header Summary
Version: 1.0
Source ID: 0
Reserved: 0
Project ID/GUID: '00000000-0000-0000-0000-000000000000'
System ID: ''
Generating Software: 'TerraScan'
File Creation Day/Year: 0/0
Header Byte Size 227
Data Offset: 759
Header Padding: 2
v.in.lidar -p input=D:\temp\lidartest\Serpent_Mound_Model_LAS_Data.las
Using LAS Library Version 'libLAS 1.8.0 with GeoTIFF 1.4.0 GDAL 1.11.3
LASzip 2.2.0'
LAS File Version: 1.0
System ID: ''
Point Data Format: 1
Number of Point Records: 3265110
Number of Points by Return: 0 0 0 0 0
Scale Factor X Y Z: 0.01 0.01 0.01
Offset X Y Z: -0 -0 -0
Min X Y Z: 289021 4.32094e+006 166.78
Max X Y Z: 290106 4.32364e+006 215.48
Spatial Reference:
+proj=utm +zone=17 +datum=WGS84 +units=m +no_defs
Data Fields:
'X'
'Y'
'Z'
'Intensity'
'Return Number'
'Number of Returns'
'Scan Direction'
'Flighline Edge'
'Classification'
'Scan Angle Rank'
'User Data'
'Point Source ID'
'GPS Time'
v.in.lidar -e -t -b
output=Serpent_Mound_Model_pts
Die Projektionsinformationen des Eingabedatensatzes und der aktuellen
Location scheinen übereinzustimmen.
Scanning 3265110 points...
16416272 points imported (limit was 1024)
219 input points were skipped by count-based decimation
The rest of points was ignored
on this win10 64bit box it works.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2996#comment:15>
