[GRASS-dev] r.out.gdal and Rasterlite driver
Maciej Sieczka
msieczka at sieczka.org
Tue Oct 25 03:15:33 PDT 2016
W dniu 25.10.2016 o 12:02, Vincent Bain pisze:
> thanks for your suggestion. In fact, the script runs without error or
> warning but it does not change anything :
> gdalinfo Rasterlite:my_db.sqlite,table=my_raster
> AUTHORITY["EPSG","54321"]]
> gdal_edit.py -a_srs EPSG:12345 \
What is EPSG:12345? This doesn't look like a common EPSG SRID. If you
want to use it with GDAL, you would need to make sure it's defined in
GDAL support files.
From https://trac.osgeo.org/grass/ticket/3191#comment:1 it looks like
you are after EPSG:31255 actually. Does this one work with gdal_edit.py?
> Anyway, on the spatialite> prompt it's a matter of seconds...
> Le mardi 25 octobre 2016 à 11:39 +0200, Maciej Sieczka a écrit :
>> W dniu 24.10.2016 o 14:06, Vincent Bain pisze:
>>> Unfortunately this is not a valid lco...
>>> OK, it is not really a critical issue as we can easily solve it whether
>>> via gdal_translate or via a simple sql update,
>> Maybe `gdal_edit.py -a_srs' will be the simplest workaround?
