[GRASS-dev] r.out.gdal and Rasterlite driver
Vincent Bain bain at toraval.fr
Tue Oct 25 03:18:23 PDT 2016
no, no : it was just an imaginary srid for the example.
V.
Le mardi 25 octobre 2016 à 12:15 +0200, Maciej Sieczka a écrit :
> W dniu 25.10.2016 o 12:02, Vincent Bain pisze:
> > thanks for your suggestion. In fact, the script runs without error or
> > warning but it does not change anything :
> >         gdalinfo Rasterlite:my_db.sqlite,table=my_raster
> >             AUTHORITY["EPSG","54321"]]
> >         gdal_edit.py -a_srs EPSG:12345 \
> What is EPSG:12345? This doesn't look like a common EPSG SRID. If you
> want to use it with GDAL, you would need to make sure it's defined in
> GDAL support files.
>  From https://trac.osgeo.org/grass/ticket/3191#comment:1 it looks like
> you are after EPSG:31255 actually. Does this one work with gdal_edit.py?
> > Anyway, on the spatialite> prompt it's a matter of seconds...
> > Le mardi 25 octobre 2016 à 11:39 +0200, Maciej Sieczka a écrit :
> >> W dniu 24.10.2016 o 14:06, Vincent Bain pisze:
> >>> Unfortunately this is not a valid lco...
> >>> OK, it is not really a critical issue as we can easily solve it whether
> >>> via gdal_translate or via a simple sql update,
> >> Maybe `gdal_edit.py -a_srs' will be the simplest workaround?
