[GRASS-dev] [GRASS GIS] #3149: Adding database information to v.info metadata output
trac at osgeo.org
Sun Sep 11 02:43:58 PDT 2016
Reporter: huhabla | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.2.0
Component: Default | Version: svn-releasebranch72
Resolution: | Keywords: vector, info, v.info
CPU: Unspecified | Platform: Unspecified
Comment (by huhabla):
Replying to [comment:2 mlennert]:
> Why do you need this in v.info and what's wrong with v.db.connect -p ?
Why is this information not present in v.info? Why do we need a second
command to get this information about a vector map? The output of
v.db.connect -g is not well designed for parsing, neither for bash nor for
the python-grass-script library.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3149#comment:3>
