[GRASS-dev] [GRASS GIS] #3149: Adding database information to v.info metadata output
trac at osgeo.org
Sun Sep 11 03:12:54 PDT 2016
Reporter: huhabla | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.2.0
Component: Default | Version: svn-releasebranch72
Resolution: | Keywords: vector, info, v.info
CPU: Unspecified | Platform: Unspecified
Comment (by mlennert):
Replying to [comment:3 huhabla]:
> Replying to [comment:2 mlennert]:
> > Why do you need this in v.info and what's wrong with v.db.connect -p ?
> Why is this information not present in v.info? Why do we need a second
command to get this information about a vector map?
Because it's module that manages that setting that provides the info, as
with other modules (e.g. v.category).
>The output of v.db.connect -g is not well
>designed for parsing, neither for bash
>nor for the python-grass-script library.
Then let us improve that :-)
Just to be clear: this is not a -1 to your idea. I just want to make sure
we think about it. In general, I'm wary of introducing the same
functionality in two different modules. IMHO, it creates the risk of
feature bloat and of confusion for the users.
Ticket URL: <http://trac.osgeo.org/grass/ticket/3149#comment:4>
