[GRASS-dev] version difference between addon and GRASS core: automatic or only when relevant libraries change ?
Helmut Kudrnovsky hellik at web.de
Wed Sep 14 03:08:06 PDT 2016
Markus Neteler wrote
> On Wed, Sep 14, 2016 at 11:34 AM, Moritz Lennert
> mlennert at .worldonline
> > wrote:
>> A colleague is using a dev version of GRASS 7.2 installed on windows.
>> Trying to use a C-addon (r.object.geometry), he got an error about
>> version mismatch between the installed GRASS revision and the revision
>> of the GRASS base the addon was built against.
> Yes, because AFAIK the addons are built against 7.0.
> With the ucoming release of 7.2. I expect that this will become the
> base for addon compilation on Windows. But Martin will know more.
>> Does this message automatically appear when the revisions are
>> different, or only if relevant libraries have changed between the
>> revisions ? I imagine that the latter would not be easy, but does the
>> former really have to lead to a fatal error ?
> The libraries changed between 7.0.x and 7.2.x (see
> https://trac.osgeo.org/grass/wiki/Release/7.2.0-News#Librarychanges).
> To my knowledge no binary compatibility is possible when it comes to C
> code.
> Markus
> grass-dev mailing list
> grass-dev at .osgeo
> http://lists.osgeo.org/mailman/listinfo/grass-dev
AFAIK the addons for Windows are compiled against the several branches and
trunk, E.g.
https://wingrass.fsv.cvut.cz/grass73/x86_64/addons/grass-7.3.svn/
Etc
But there seems to be some compiling /building issues as there are no
dailies available.
normally winGRASS addons are compiled against the correct revision.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/version-difference-between-addon-and-GRASS-core-automatic-or-only-when-relevant-libraries-change-tp5285778p5285793.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
