[GRASS-dev] Submitting rules for images and r.viewshed example
Markus Neteler
neteler at osgeo.org
Wed Sep 14 23:41:43 PDT 2016
On Thu, Sep 15, 2016 at 3:11 AM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> Hi all,
> looking at r69472 I wonder if we want to change submitting rules. The
> current guideline is saying 600px width. Consequently both the image and the
> max are image takes in the page is 600px. The height is assumed to be
> smaller than that (I assume). The image in r69472 is wider in the page
> itself and the actual image is lager as well.
Yes, this follows the ideas implemented in the wxGUI modeler manual page:
https://grass.osgeo.org/grass72/manuals/wxGUI.gmodeler.html
The original attempt to respect the 600px with was a failure due to
unreadability of the menus.
Hence Ludka developed the way to make the images clickable and
autoscale to 600px in the browser rendering when being in full page
mode.
> I actually like the clickable images as a way of showing full detail
The other advantage is that having higher resolution/extent images
available does not prevent from using them in presentations.
Many older screenshots are unusable for that reason.
Please note that the original file size has been reduced with these tools
- pnqnq (reducing colors by quantization)
- optipng (optimize compression)
> but
> then the question is what should be size in the page.
600px width. The height often depends on the topic or input data.
> And another question
> is what about the download size of the images (we have be conserving size
> till now).
... as small as possible :-)
> And related to that, do we need thumb nails (might be too
> complicated but also might be done automatically)?
I don't think that thumbnails are of any use. They are just unreadable
and since we don't know on which device the manual will be rendered I
like Ludka's autoscale approach much better.
So: I am all for optimizing our submission rules to reflect the
improved approach.
cheers,
Markus
> Best,
> Vaclav
> https://trac.osgeo.org/grass/changeset/69472
> https://trac.osgeo.org/grass/wiki/Submitting/Docs#Images
