[GRASS-dev] [GRASS GIS] #2055: r.in.gdal lacks flag "-r Limit import to the current region"
trac at osgeo.org
Fri Sep 16 11:57:36 PDT 2016
Reporter: neteler | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.2.0
Component: Raster | Version: svn-trunk
Resolution: | Keywords: r.in.gdal, r.import
CPU: Unspecified | Platform: Unspecified
Comment (by mmetz):
Replying to [comment:17 martinl]:
> You are right, the patch lacks tests - it was just proof-of-concept. I
will implement them in the next patch.
The concept is proofed when the patch is working.
With
/* get pixel coordinates defined by current region */
pixel_start = (int) (cellhd.west - adfGeoTransform[0]) /
adfGeoTransform[1];
line_start = (int) (cellhd.north - adfGeoTransform[3]) /
adfGeoTransform[5];
pixel_end = (int) (cellhd.east - adfGeoTransform[0]) /
adfGeoTransform[1];
line_end = (int) (cellhd.south - adfGeoTransform[3]) /
adfGeoTransform[5];
you cast the numerator of the division to int while `Rast_align_window()`
uses `floor()` and `ceil()` for the equivalent calculations. Why?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2055#comment:18>
