[GRASS-dev] t.register: ERROR: Unable to register raster map - The map has no timestamp and the start time is not set.
Helmut Kudrnovsky
hellik at web.de
Sun Sep 25 02:16:11 PDT 2016
hi,
I've downloaded the E-OBS datafiles 1950-01-01 - 2015-12-31 data; imported
the precipitation data by r.in.gdal.
the rasters are:
prec.00001
prec.00002
prec.00003
the I do following steps accordingly (in accordance to the manual):
t.create --verbose output=precipitation_sum_1950_2015_daily semantictype=sum
title=European precipitation sum daily 1950-2015 description=The European
daily precipitation sum
Creating a new space time raster dataset
t.list -c columns=id,name,creator,mapset,granularity
Space time raster datasets with absolute time available in
mapset <ecad>:
id|name|creator|mapset|granularity
precipitation_sum_1950_2015_daily at ecad|precipitation_sum_1950_2015_daily|bugs|ecad|None
prec_list.txt:
prec.00001
prec.00002
prec.00003
prec.24104
prec.24105
prec.24106
t.register -i --verbose input=precipitation_sum_1950_2015_daily at ecad
file=/home/bugs/wd/climate_data/ecad/prec_list.txt start=1950-01-01
unit=days increment="1 days" separator=newline
WARNING: The increment option will be ignored because of time stamps in
input file
WARNING: The interval flag will be ignored because of time stamps in input
file
Gathering map information...
ERROR: Unable to register raster map <prec.00001 at ecad>. The map has no
the example from the manual:
# register daily maps using the file created above
t.register -i type=raster input=temperature_mean_1950_2015_daily \
file=map_list.txt start=1950-01-01 increment="1 days"
any ideas?
tested with a self compiled
System Info
GRASS version: 7.3.svn
GRASS SVN revision: r69569
Build date: 2016-09-25
Build platform: x86_64-pc-linux-gnu
GDAL: 2.1.1
PROJ.4: 4.8.0
GEOS: 3.4.2
SQLite: 3.8.7.1
Python: 2.7.9
wxPython: 3.0.1.1
Platform: Linux-3.16.0-4-amd64-x86_64-with-debian-8.6
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/t-register-ERROR-Unable-to-register-raster-map-The-map-has-no-timestamp-and-the-start-time-is-not-se-tp5287609.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
