[GRASS-dev] t.register: ERROR: Unable to register raster map - The map has no timestamp and the start time is not set.
Sören Gebbert
soerengebbert at googlemail.com
Sun Sep 25 02:21:33 PDT 2016
remove option "separator=newline". It should only be used if there are
time-stamps in the file.
Best regards
Soeren
2016-09-25 11:16 GMT+02:00 Helmut Kudrnovsky <hellik at web.de>:
> hi,
> I've downloaded the E-OBS datafiles 1950-01-01 - 2015-12-31 data; imported
> the precipitation data by r.in.gdal.
> the rasters are:
> prec.00001
> prec.00002
> prec.00003
> the I do following steps accordingly (in accordance to the manual):
> t.create --verbose output=precipitation_sum_1950_2015_daily
> semantictype=sum
> title=European precipitation sum daily 1950-2015 description=The European
> daily precipitation sum
> Creating a new space time raster dataset
> t.list -c columns=id,name,creator,mapset,granularity
> Space time raster datasets with absolute time available in
> mapset <ecad>:
> id|name|creator|mapset|granularity
> precipitation_sum_1950_2015_daily at ecad|precipitation_sum_
> 1950_2015_daily|bugs|ecad|None
> prec_list.txt:
> prec.00001
> prec.00002
> prec.00003
> prec.24104
> prec.24105
> prec.24106
> t.register -i --verbose input=precipitation_sum_1950_2015_daily at ecad
> file=/home/bugs/wd/climate_data/ecad/prec_list.txt start=1950-01-01
> unit=days increment="1 days" separator=newline
> WARNING: The increment option will be ignored because of time stamps in
> input file
> WARNING: The interval flag will be ignored because of time stamps in input
> file
> Gathering map information...
> ERROR: Unable to register raster map <prec.00001 at ecad>. The map has no
> the example from the manual:
> # register daily maps using the file created above
> t.register -i type=raster input=temperature_mean_1950_2015_daily \
> file=map_list.txt start=1950-01-01 increment="1 days"
> any ideas?
> tested with a self compiled
> System Info
> GRASS version: 7.3.svn
> GRASS SVN revision: r69569
> Build date: 2016-09-25
> Build platform: x86_64-pc-linux-gnu
> GDAL: 2.1.1
> PROJ.4: 4.8.0
> GEOS: 3.4.2
> SQLite: 3.8.7.1
> Python: 2.7.9
> wxPython: 3.0.1.1
> Platform: Linux-3.16.0-4-amd64-x86_64-with-debian-8.6
> best regards
> Helmut
> View this message in context: http://osgeo-org.1560.x6.
> nabble.com/t-register-ERROR-Unable-to-register-raster-map-
> The-map-has-no-timestamp-and-the-start-time-is-not-se-tp5287609.html
> Sent from the Grass - Dev mailing list archive at Nabble.com.
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160925/e3ca3c31/attachment-0001.html>
