[GRASS-dev] t.register: ERROR: Unable to register raster map - The map has no timestamp and the start time is not set.
Sören Gebbert
soerengebbert at googlemail.com
Sun Sep 25 02:29:04 PDT 2016
Am 25.09.2016 11:26 schrieb "Helmut Kudrnovsky" <hellik at web.de>:
> >Hi,
> >remove option "separator=newline". It should only be used if there are
> time-stamps in the file.
> >Best regards
> >Soeren
> t.register -i --verbose input=precipitation_sum_1950_2015_daily at ecad
> file=/home/bugs/wd/climate_data/ecad/prec_list.txt start=1950-01-01
> increment=1 days
> Gathering map information...
> Registering maps in the temporal database...
> Registering maps in the space time dataset...
> Updating space time dataset...
> Update metadata, spatial and temporal extent from all registered maps of
> <precipitation_sum_1950_2015_daily at ecad>
> is registering now.
> from the manual:
> unit=string
> Time stamp unit
> Unit must be set in case of relative time stamps
> Options: years, months, days, hours, minutes, seconds
> in the case of this data set, is it necessary to define the unit?
It is not necessary since you are using absolute time.
Best regards
Soeren
> best regards
> Helmut
http://osgeo-org.1560.x6.nabble.com/t-register-ERROR-Unable-to-register-raster-map-The-map-has-no-timestamp-and-the-start-time-is-not-se-tp5287609p5287613.html
> Sent from the Grass - Dev mailing list archive at Nabble.com.
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160925/d10e76b7/attachment.html>
