[GRASS-dev] t.register: ERROR: Unable to register raster map - The map has no timestamp and the start time is not set.
Veronica Andreo
veroandreo at gmail.com
Sun Sep 25 02:32:02 PDT 2016
Hello Helli,
On the road now and cannot test, but til Friday that was working for me...
Can you please test adding double quotes around start date
(start="1950-01-01")? Or they are there, but just don't appear in the
email? Seems to me it might not be recognizing the start option as you have
set it...
HTH,
Vero
El sept. 25, 2016 11:16 AM, "Helmut Kudrnovsky" <hellik at web.de> escribió:
> hi,
> I've downloaded the E-OBS datafiles 1950-01-01 - 2015-12-31 data; imported
> the precipitation data by r.in.gdal.
> the rasters are:
> prec.00001
> prec.00002
> prec.00003
> the I do following steps accordingly (in accordance to the manual):
> t.create --verbose output=precipitation_sum_1950_2015_daily
> semantictype=sum
> title=European precipitation sum daily 1950-2015 description=The European
> daily precipitation sum
> Creating a new space time raster dataset
> t.list -c columns=id,name,creator,mapset,granularity
> Space time raster datasets with absolute time available in
> mapset <ecad>:
> id|name|creator|mapset|granularity
> precipitation_sum_1950_2015_daily at ecad|precipitation_sum_
> 1950_2015_daily|bugs|ecad|None
> prec_list.txt:
> prec.00001
> prec.00002
> prec.00003
> prec.24104
> prec.24105
> prec.24106
> t.register -i --verbose input=precipitation_sum_1950_2015_daily at ecad
> file=/home/bugs/wd/climate_data/ecad/prec_list.txt start=1950-01-01
> unit=days increment="1 days" separator=newline
> WARNING: The increment option will be ignored because of time stamps in
> input file
> WARNING: The interval flag will be ignored because of time stamps in input
> file
> Gathering map information...
> ERROR: Unable to register raster map <prec.00001 at ecad>. The map has no
> the example from the manual:
> # register daily maps using the file created above
> t.register -i type=raster input=temperature_mean_1950_2015_daily \
> file=map_list.txt start=1950-01-01 increment="1 days"
> any ideas?
> tested with a self compiled
> System Info
> GRASS version: 7.3.svn
> GRASS SVN revision: r69569
> Build date: 2016-09-25
> Build platform: x86_64-pc-linux-gnu
> GDAL: 2.1.1
> PROJ.4: 4.8.0
> GEOS: 3.4.2
> SQLite: 3.8.7.1
> Python: 2.7.9
> wxPython: 3.0.1.1
> Platform: Linux-3.16.0-4-amd64-x86_64-with-debian-8.6
> best regards
> Helmut
> View this message in context: http://osgeo-org.1560.x6.
> nabble.com/t-register-ERROR-Unable-to-register-raster-map-
> The-map-has-no-timestamp-and-the-start-time-is-not-se-tp5287609.html
> Sent from the Grass - Dev mailing list archive at Nabble.com.
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160925/06b4aeb8/attachment.html>
