[GRASS-dev] t.register: ERROR: Unable to register raster map - The map has no timestamp and the start time is not set.
Veronica Andreo
veroandreo at gmail.com
Sun Sep 25 02:36:43 PDT 2016
Forget what I said :)
Thanks Sören!
Vero
El sept. 25, 2016 11:32 AM, "Veronica Andreo" <veroandreo at gmail.com>
escribió:
> Hello Helli,
> On the road now and cannot test, but til Friday that was working for me...
> Can you please test adding double quotes around start date
> (start="1950-01-01")? Or they are there, but just don't appear in the
> email? Seems to me it might not be recognizing the start option as you have
> set it...
> HTH,
> Vero
> El sept. 25, 2016 11:16 AM, "Helmut Kudrnovsky" <hellik at web.de> escribió:
>> hi,
>> I've downloaded the E-OBS datafiles 1950-01-01 - 2015-12-31 data; imported
>> the precipitation data by r.in.gdal.
>> the rasters are:
>> prec.00001
>> prec.00002
>> prec.00003
>> the I do following steps accordingly (in accordance to the manual):
>> t.create --verbose output=precipitation_sum_1950_2015_daily
>> semantictype=sum
>> title=European precipitation sum daily 1950-2015 description=The European
>> daily precipitation sum
>> Creating a new space time raster dataset
>> t.list -c columns=id,name,creator,mapset,granularity
>> Space time raster datasets with absolute time available in
>> mapset <ecad>:
>> id|name|creator|mapset|granularity
>> precipitation_sum_1950_2015_daily at ecad|precipitation_sum_195
>> 0_2015_daily|bugs|ecad|None
>> prec_list.txt:
>> prec.00001
>> prec.00002
>> prec.00003
>> prec.24104
>> prec.24105
>> prec.24106
>> t.register -i --verbose input=precipitation_sum_1950_2015_daily at ecad
>> file=/home/bugs/wd/climate_data/ecad/prec_list.txt start=1950-01-01
>> unit=days increment="1 days" separator=newline
>> WARNING: The increment option will be ignored because of time stamps in
>> input file
>> WARNING: The interval flag will be ignored because of time stamps in input
>> file
>> Gathering map information...
>> ERROR: Unable to register raster map <prec.00001 at ecad>. The map has no
>> the example from the manual:
>> # register daily maps using the file created above
>> t.register -i type=raster input=temperature_mean_1950_2015_daily \
>> file=map_list.txt start=1950-01-01 increment="1 days"
>> any ideas?
>> tested with a self compiled
>> System Info
>> GRASS version: 7.3.svn
>> GRASS SVN revision: r69569
>> Build date: 2016-09-25
>> Build platform: x86_64-pc-linux-gnu
>> GDAL: 2.1.1
>> PROJ.4: 4.8.0
>> GEOS: 3.4.2
>> SQLite: 3.8.7.1
>> Python: 2.7.9
>> wxPython: 3.0.1.1
>> Platform: Linux-3.16.0-4-amd64-x86_64-with-debian-8.6
>> best regards
>> Helmut
>> View this message in context: http://osgeo-org.1560.x6.nabbl
>> e.com/t-register-ERROR-Unable-to-register-raster-map-The-
>> map-has-no-timestamp-and-the-start-time-is-not-se-tp5287609.html
>> Sent from the Grass - Dev mailing list archive at Nabble.com.
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160925/f7cd4c3a/attachment-0001.html>
