[GRASS-dev] [GRASS GIS] #3167: db.connect: connection to remote database does not work
GRASS GIS trac at osgeo.org
Mon Sep 26 06:32:36 PDT 2016
 Reporter:  mlennert               |      Owner:  grass-dev@…
     Type:  defect                 |     Status:  new
 Priority:  blocker                |  Milestone:  7.0.5
Component:  Database               |    Version:  unspecified
 Keywords:  postgresql db.connect  |        CPU:  Unspecified
 Platform:  Unspecified            |
 In a freshly compiled 70release:
 createdb -h myRemoteServer testgrass
 grass70 -c /data/GRASS/DATA7/nc_spm_08/postgres_test
 db.connect driver=pg database="host=myRemoteServer,dbname=testgrass"
 > db.tables -p
 DBMI-PostgreSQL erreur de pilote :
 Connection failed.
 FATAL:  la base de données « testgrass » n'existe pas
 Connection failed.
 ERREUR :Unable to open database
         <host=myRemoteServer,dbname=testgrass>
 and
 > g.copy vect=boundary_county,bc
 Copy vector <boundary_county at PERMANENT> to current mapset as <bc>
 DBMI-PostgreSQL driver error:
 Connection failed.
 Connection failed.
 WARNING: Unable to open database
          <host=myRemoteServer,dbname=testgrass> by driver
          <pg>
 no database is open
 no database is open
 WARNING: Unable to copy table <bc>
 WARNING: Unable to copy table <boundary_county> for layer 1 from
          <boundary_county at PERMANENT> to <bc>
 but
 > psql -h myRemoteServer -l | grep testgrass
  testgrass              | mlennert    | UTF8      | C       | C     |
Ticket URL: <https://trac.osgeo.org/grass/ticket/3167>
