[GRASS-dev] [GRASS GIS] #3167: db.connect: connection to remote database does not work
trac at osgeo.org
Mon Sep 26 07:09:45 PDT 2016
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 7.0.5
Component: Database | Version: unspecified
Resolution: | Keywords: postgresql db.connect
CPU: Unspecified | Platform: Unspecified
Comment (by mlennert):
g.gisenv set=DEBUG=3
db.tables -p
D1/3: G_set_program_name(): db.tables
D2/3: G_file_name(): path = /data/GRASS/DATA7/nc_spm_08/postgres_test
D2/3: dbDbmscap(): opendir
[/data/home/mlennert/SRC/GRASS/grass70_release/dist.x86_64-pc-linux-
gnu/driver/db/]
gnu/driver/db/]
D1/3: db_d_init_error(): PostgreSQL
D3/3: db_get_login(): drv=[pg] db=[host=myRemoteServer,dbname=testgrass]
D3/3: read_file(): DB login file = </home/mlennert/.grass7/dblogin>
D3/3: login file does not exist
D3/3: db_driver_open_database(): driver=pg database definition =
'host=myRemoteServer,dbname=testgrass'
D3/3: parse_conn: 'host=myRemoteServer,dbname=testgrass'
D3/3: token 0 : host=myRemoteServer
D3/3: token 1 : dbname=testgrass
D3/3: db_driver_open_database(): host = (null), port = (null), options =
(null), tty = (null), dbname = testgrass, user = (null), password = (null)
schema = (null)
db.login driver=pg database=host=myRemoteServer,dbname=testgrass
db.tables -pD1/3: G_set_program_name(): db.tables
gnu/driver/db/]
gnu/driver/db/]
D3/3: ret = 2 : drv=[pg] db=[host=myRemoteServer,dbname=testgrass] usr=[]
pwd=[] host=[], port=[]
schema = (null)
So the host name gets lost somewhere on the way.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3167#comment:1>
