[GRASS-dev] [GRASS GIS] #2848: g.gui.vdigit: snapping distance seems to only be defined in map units, not screen pixels
GRASS GIS trac at osgeo.org
Mon Sep 26 07:19:32 PDT 2016
screen pixels
  Reporter:  mlennert     |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  major        |  Milestone:  7.0.5
 Component:  wxGUI        |    Version:  svn-releasebranch70
Resolution:               |   Keywords:  vector, digitize
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by mlennert):
 Replying to [comment:6 annakrat]:
 > Please test. It was only problem when using different locale.
 Right. It +/- works now, i.e. when I chose "screen pixels", I now get the
 correct value in map units below. However, when I change the value (i.e.
 the number of screen pixels), I get a wrong number below: the number of
 screen pixels instead of map units. I have to switch to map units and back
 to screen pixels for the depicted value in map units to be correct again.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2848#comment:7>
