[GRASS-dev] [GRASS GIS] #2848: g.gui.vdigit: snapping distance seems to only be defined in map units, not screen pixels
GRASS GIS trac at osgeo.org
Mon Sep 26 08:03:59 PDT 2016
screen pixels
  Reporter:  mlennert     |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  major        |  Milestone:  7.0.5
 Component:  wxGUI        |    Version:  svn-releasebranch70
Resolution:               |   Keywords:  vector, digitize
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by annakrat):
 Replying to [comment:7 mlennert]:
 > Replying to [comment:6 annakrat]:
 > > Please test. It was only problem when using different locale.
 > Right. It +/- works now, i.e. when I chose "screen pixels", I now get
 the correct value in map units below. However, when I change the value
 (i.e. the number of screen pixels), I get a wrong number below: the number
 of screen pixels instead of map units. I have to switch to map units and
 back to screen pixels for the depicted value in map units to be correct
 again.
 OK, I committed a new fix in r69579.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2848#comment:8>
