[GRASS-dev] Adding an expert mode to the parser
Moritz Lennert
mlennert at club.worldonline.be
Mon Sep 26 22:13:37 PDT 2016
On 26/09/16 23:50, Vaclav Petras wrote:
> On Mon, Sep 26, 2016 at 5:24 PM, Veronica Andreo <veroandreo at gmail.com
> <mailto:veroandreo at gmail.com>> wrote:
> I'm with MaDi in that if I see a very long list of flags and
> parameters in the terminal when using --h, i just go to the
> manual... I just use --h in CLI for a quick recalling of
> flags/options... A reduced list of most commonly used flags would be
> nice, but still keep the possibility to get the advanced
> flags/parameters as well, if the user needs more info...
> If the --help is just for scanning and the issue is that it simply too
> long, hiding some parameters is not the only option we have. For many
> (and more in the future hopefully) parameters we have (short) label and
> (longer) description. --help prints both (if both are present, that's at
> least 2 lines per parameter). Additionally, if the option has predefined
> values which have descriptions, there is one line for each of those. So,
> the question is would it be helpful (at least as a first step) if --help
> would print less information for each parameter but still provided all
> parameters?
In line with your other mail where you caution about "hiding" useful
information, how about not changing the --help output, but rather adding
a "--simple-help" or somthing like this which would output a simplified
help. Although:
> and manual pages then (a tab or section for advanced
> flags/parameters)...
> Considering that we have currently as system of (gui) sections which
> place the options to individual tabs in GUI, isn't showing the different
> sections in the manual the right thing to do?
I would prefer this: show everything, but structure it differently, i.e.
possibly introduce a new parser keyword (advanced: yes) which would put
the option into a specific section of the manual. IMHO, this should be
independent of the GUI sections logic as one might to group less
advanced and advanced options in the same thematic tab...
> IMHO, a major issue however is the lack of examples for the usage of
> more advanced flags or options (or even the required and more common
> ones). Take the case of several i.* modules, for example... but maybe
> this should go in a separate thread :-)
> Good point. If you have an explanation and example for a flag, perhaps
> you can understand it and it is not so advanced at the end.
I think this is actually a major issue: man pages without description,
notes and example sections are almost useless IMHO. At the foss4g.be
last week someone presented a simple use of GRASS GIS (to create this
map [1] for television) and explained how he actually found the GRASS
GIS manual system extremely well done and useful, because of the
explanations and examples...
Moritz
[1] http://www.rtbf.be/services/meteo/apere
