[GRASS-dev] Adding an expert mode to the parser
Margherita Di Leo
diregola at gmail.com
Tue Sep 27 00:15:53 PDT 2016
On Tue, Sep 27, 2016 at 7:13 AM, Moritz Lennert <
mlennert at club.worldonline.be> wrote:
> On 26/09/16 23:50, Vaclav Petras wrote:
>> On Mon, Sep 26, 2016 at 5:24 PM, Veronica Andreo <veroandreo at gmail.com
>> <mailto:veroandreo at gmail.com>> wrote:
>> I'm with MaDi in that if I see a very long list of flags and
>> parameters in the terminal when using --h, i just go to the
>> manual... I just use --h in CLI for a quick recalling of
>> flags/options... A reduced list of most commonly used flags would be
>> nice, but still keep the possibility to get the advanced
>> flags/parameters as well, if the user needs more info...
>> If the --help is just for scanning and the issue is that it simply too
>> long, hiding some parameters is not the only option we have. For many
>> (and more in the future hopefully) parameters we have (short) label and
>> (longer) description. --help prints both (if both are present, that's at
>> least 2 lines per parameter). Additionally, if the option has predefined
>> values which have descriptions, there is one line for each of those. So,
>> the question is would it be helpful (at least as a first step) if --help
>> would print less information for each parameter but still provided all
>> parameters?
> In line with your other mail where you caution about "hiding" useful
> information, how about not changing the --help output, but rather adding a
> "--simple-help" or somthing like this which would output a simplified help.
+1.
> Although:
> and manual pages then (a tab or section for advanced
>> flags/parameters)...
>> Considering that we have currently as system of (gui) sections which
>> place the options to individual tabs in GUI, isn't showing the different
>> sections in the manual the right thing to do?
> I would prefer this: show everything, but structure it differently, i.e.
> possibly introduce a new parser keyword (advanced: yes) which would put the
> option into a specific section of the manual. IMHO, this should be
> independent of the GUI sections logic as one might to group less advanced
> and advanced options in the same thematic tab...
+1 also here :-)
> IMHO, a major issue however is the lack of examples for the usage
>> of
>> more advanced flags or options (or even the required and more
>> common
>> ones). Take the case of several i.* modules, for example... but
>> maybe
>> this should go in a separate thread :-)
> > Good point. If you have an explanation and example for a flag, perhaps
> > you can understand it and it is not so advanced at the end.
> I think this is actually a major issue: man pages without description,
> notes and example sections are almost useless IMHO. At the foss4g.be last
> week someone presented a simple use of GRASS GIS (to create this map [1]
> for television) and explained how he actually found the GRASS GIS manual
> system extremely well done and useful, because of the explanations and
> examples...
+1000 :-)
So this afternoon at the GRASS meetup [
https://grasswiki.osgeo.org/wiki/GRASS_GIS_Ispra_meetups_2016] we can give
a meaningful example on how users can contribute to GRASS without coding
Cheers,
madi
> Moritz
> [1] http://www.rtbf.be/services/meteo/apere
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
Margherita Di Leo
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160927/930ce7d8/attachment-0001.html>
